P pitbullmom123 Reputable May 12, 2015 1 0 4,510 May 12, 2015 #1 I'm building my first computer and I'm trying to determine if the cpu I'm buying I 32 or 64. http://pcpartpicker.com/part/intel-cpu-bx80646i54460
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 May 12, 2015 Solution #2 This will explain - http://www.computerhope.com/issues/ch001121.htm Upvote 0 Downvote Solution
P pcgaming98 Honorable Jan 24, 2014 1,067 0 11,660 May 12, 2015 #3 You'll practically have to Google it if the seller site doesn't already list it. Anyway, that's definitely a 64 bit CPU. Upvote 0 Downvote
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 May 12, 2015 #4 http://pcpartpicker.com/part/intel-cpu-bx80646i54460 In the specs it states 64-bit CPU. Upvote 0 Downvote
M mbarnes86 Splendid Sep 16, 2010 3,839 7 26,965 May 12, 2015 #5 Hi Apart from early Intel atom CPU all modern Intel & and CPU's are 64 bit Most new pc's have 64 bit version of windows pre installed even if less than 4 GB of ram ( again exception for a few tablets using Intel Atom CPU) Regards Mike Barnes Upvote 0 Downvote
Wolfshadw Titan Moderator Aug 3, 2006 28,523 1,699 133,290 May 12, 2015 #6 Just about every desktop processor produced in the last decade has been 64-bit. You shouldn't need to worry about it. -Wolf sends Upvote 0 Downvote
