Question How To Tell if Motherboard Killed CPU
Lovin1995
Commendable
Jul 7, 2019
Hello everyone!
The other day I was playing a game on my PC, and all of a sudden it shut off, almost like a power surge. It turned back on and I used it again for an hour or two before it shut off again. This time, however, I could not get it to turn back on. I tried resetting my BIOS, clearing CMOS, etc etc, and eventually I realized one of my components must have died.
So the symptoms I was having were the motherboard RGB and all my fans would turn on, but my display would never come up. I noticed that my keyboard never connected as well, so I figured it was not my GPU. Unfortunately my motherboard had no speaker or LED diagnosis lights, so I had to guess what was wrong. I ended up trying a different PSU, motherboard, and RAM, and none of them worked. The new motherboard had LED debug, and the CPU light is consistently on.
As far as the CPU goes, I had not had any real issues with it until a couple of weeks ago. My AIO stopped working for a brief period of time, and my system shut itself down from CPU overheating two or three times before I got it fixed. I had no other issues before then.
So my question is, I know I will need to get a new CPU, but do I need to avoid using my original motherboard? What is the likelihood that my motherboard fried the CPU vs I just had a faulty one? I'd like to avoid replacing every component if I need to, but if it's necessary then it is what it is.
Specs:
Ryzen 5 5600X
RTX 3080
16 GB RAM
Gigabyte X570 Aorus Elite Wifi (Original Motherboard)
MSI B550 Gaming Pro (replacement board I can return if the old one is safe)
Lovin1995
Commendable
Jul 7, 2019
what was your power supply?
your CPU is relatively low power model, your mainboard has way robust power delivery
if you had PBO enabled, it does void warranty
It’s a Gamemax 850W.
and I don’t believe I had PBO enabled. I never OC’d or anything.
