Hi,
After looking around a ton I'm still stuck on this one question. How can I tell which CPUs will be the same number of pins or same type/size/shape as my current i3-2328M? I'm hoping to upgrade to an i7 if possible.
It's an Acer V3-571-6447 and before you go saying "you can't replace a laptop CPU as it's soldered on" it's not. That was consistently the only answer I found over and over again which is obviously wrong since I already have the i3-2328M in my hand.
What else do I need to look into to know what can be upgraded to?
Thanks!
Thanks!
