How to test a PCI-E cable?
Retro_
21
Hi, So recentley my graphics card fried... I left for a bit and when I came back my computer wouldnt boot up. The not booting problem is now fixed because I figured out that I had to remove the PCI-E cable from my graphics card and it would boot up again. But now Im starting to blue screen constantly and my computer will slow down over time before doing so. My solution?
Getting a new graphics card (1080) and a new hard drive to hopefully fix my blue screening. But since im spending 600 dollars on a graphics card I want to know how to test my PCI-E cable so I can be safe and know that as soon as I plug my PCI-E cable into the graphics card it wont die on me and RIP $600.
Everything else seems to be working fine im using my onboard graphics card Intel HD 4600 but in general is there a safe way to make sure my PCI-E isnt over volting anything.
Further, it is difficult to measure the output watts (at home). This is because it requires the power supply to be under load at he same time the watts are measured. The power supply can be taken to a PC repair shop and have them test it. But you may as well put that expense towards a new one.
DSzymborski , my power supply is an EVGA SuperNova 750W B1 80+
Ikr, I did my research before buying my power supply and it seemed good so I got it. At the moment im just weary on doing anything because my graphics card stopped working and had this burnt smell out of nowhere and now even though I am not using a graphics card my PC randomly slows down and then blue screens. Which is why im getting a new HDD as well.
I would say that it is probably still in good shape. I wouldn't be to concerned about the power supply unless you have some power related problems.
Yea true, But im still confused on how my graphics card can just randomly fry when I left my house for the day, I mean my computer is on carpet so that could be something and after all this my computer just randomly slows down like 30 minutes after bootup and then bluescreens.
