M MaxMac Feb 15, 2019 2 0 10 Feb 15, 2019 #1 Is there a program for testing monitors ports using a PC? I need some way to save "results" showing that a monitor ports have been tested and worked
Wolfshadw Titan Moderator Aug 3, 2006 28,515 1,696 133,290 Feb 15, 2019 #2 I'm not aware of any such program, but even if something like that did exist, what is the point? Even if the ports do report back as functional, that says nothing of the display, itself. -Wolf sends Upvote 0 Downvote
M MaxMac Feb 15, 2019 2 0 10 Feb 15, 2019 #3 Well it does say that the ports are functioning hence You can rule out one of potential sources of a problem. Upvote 0 Downvote
