[SOLVED] how to test Panasonic and Sony CCTV cameras for basic functions?
Ksingh707
Commendable
Sep 5, 2021
75
Hello, I have a Panasonic WV-CW864A CCTV camera and I need to test it to see if it is functioning prooperly, According to the manual i need a certain switch of some sort to see if the camera is functioning. I was just wondering if anyone knows if there is a universal switch or something that I can use to see if different cctv cameras are working. Or is there only specific switches for specific cameras? If anyone has any information on this I would really appreciate it thanks.
For basic seeing a video you need to provide 24VAC and an appropriate connector to convert it's video out to an RCA connector. That should be enough, alone, to see if it outputs video. A BNC to RCA should suffice.
I note that there are quite a few other more advanced controls including movement and zoom available for this so for those functions to operate you would need some manner of control hardware/software.
I used to use a device called a ToteVision for testing cameras while at the device. It is basically nothing but a small screen with video input.
Connections - Panasonic WV-CW864A Operating Instructions Manual [Page 54] | ManualsLib
Do you only have the camera or do you also have the control panel? If only the camera, it's gonna be tough to get it working.
Reactions: Ksingh707
Thank you so much for the information, this was very helpful.
