How to track network live cables?
ghini86
I will have to track and label the cables from about 20 full switches which go to patch panels. Total spaghetti! There are no labels, we have no information about where patch panels go (to which PCs) and we do not administrate the switches. We can get no reports regarding macs or anything. My question is what's the easiest way to track the cables WITHOUT unplugging them at all? (switch-patch panel, 2-10 meters long). Is there any device that could help me? I've read that Intellitone Pro 200 tracks live networks, but I can't find any indication how to actually do it. I know it has some alligator clips. If i put them directly to the outside of the cable, will they transmit any signal to use the probe to the other end? If not, any other advice besides manually track them? Help!
You have eliminated the 2 most common ways to find these. Clipping things to the outside of the cable will have no effect since the cable is designed to reject interference from outside. If you would find something that could induce a signal that would cause data loss and would be the same as unplugging it. You can get a similar device from harbor freight for $40 but it to requires you unplug the cable and plug the device in or somehow connect to the copper wire itself.
