How to turn my Netgear N150 router into a wireless adapter
ItsPepi
15
I currently have my desktop upstairs and the main router on the main floor. I want to use my Netgear G54/N150 wireless router as an adapter to be able to get good internet connection.
G54/N150 (WNR1000v4) What sort of alternate firmware do you think would work and how would I set that up?
I don't see any alternative (non Netgear) firmware that supports your router. I don't believe that router can do what you want.
UNLESS, I am mis-interpreting what you want to do... Do you want to use the router to receive WIFI and connect to your PC via wire (which is what I first thought you wanted because of your use of the word "adapter")? OR Do you want to connect the router to a wired connection back to the primary router and have a second WIFI source ?
You can't do the first. You can do the second ...
