Question How to turn off the notification's sound of a secondary monitor connected?
Manuel Jordan
286
9
4,685
Hello Friends
For laptop Dell, it has:
  • Windows 11 Home
  • A secondary monitor connected through HDMI
Until here all work fine
When is executed the Windows + P keyboard shortcut is possible see all the options to do with the secondary monitor.
Now, the reason of this post. When is not need it the secondary monitor is possible do two things:
1. Turn Off the Monitor itself (it is not used because the button itself has a weak resistance where it can get be broken)
2. Apply `PC screen only`
When is applied the second option it works but each 4 seconds sounds a "beep". Same sound when you put and unplug a pendrive (usb flash drive).
Therefore to avoid that sound is possible do any of the following options:
1. Turn on the secondary monitor
2. Reuse the secondary monitor (as either _duplicate_ or _extend_, etc)
Question
  • How to turn off the notification's sound of a secondary monitor connected?
Like an attempt was done:
  • Settings -> System-> Notifications -> Notifications (Off)
But the sound remains
Make, model and SKU for your laptop? Make and model of your monitor? Might want to see if your laptop is pending any BIOS updates and if reinstalling your chipset drivers in an elevated command, i.e, Right click installer>Run as Administrator, helps.
Can you pass on a clip of the issue you speak of?
