How to unplug DisplayPort cable.
Hrlyrdr22
188
Sorry if this is in the wrong place, don't really know where it would go.
Basically I have a GTX750 and it has a DisplayPort output. I have a DisplayPort to HDMI cable to hook up to my monitor which doesnt have displayport. Now I finally decided to redo my cable management since everything is in the front instead of behind the motherboard and it just looks horrible. Only problem is I cant unplug the DisplayPort cable so I cant move my computer...
How do I unplug the DisplayPort cable? I heard there was something that keeps it from falling out, DVI and VGA have screws but I think displayport has this... sort of like teeth sticking out to keep it from coming out. I kind of dont want to use brute force and break it because I'm using all 3 ports and if one breaks, then I basically have a useless monitor.
tl;dr DisplayPort is stuck in GPU, how do I unplug cable?
Hmm didn't see that, kinda dark under my desk. Thanks a lot man, glad I didnt rip the cable out haha.
hahaha yea well you wouldn't have ripped the cable out. Most likely pulled the PC as you tugged on it or dragged the monitor down haha
