how to update to newer better parts
ishmeetrocks
34
I wish to know what shall be the best components that i shall buy in under 400 $ to better my gaming experience..
My current build is :
Gpu : Sapphire r9 270x 2gb oc edition
Cpu : amd fx 6300 6 core processor
Psu : antec vp650p power supply
Motherboard : gigabyte ga 970a ds3p
Ram: Kingston hyperx blu 8 gb
Antec x1 t cabinet with inbuilt fans
Western digital green 1 tb hard disk
Yup if it fits the socket it will mostly always work. The processor he mentioned is an AM3+ and your motherboard has an AM3+ Socket.
Should be good.
I would:
Sell your current CPU and GPU...that money should get you an FX 8350.
Then spend your 400.00 budget on a new card, my recommendation: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125505&cm_re=amd_r9_290-_-14-125-505-_-Product [at 319.99 its a steal...reviews were mixed, but if you have a dud card...just RMA]
ASUS makes a DCU2 card for 390.00 as well:http://www.newegg.com/Product/Product.aspx?Item=N82E16814121842&cm_re=amd_r9_290-_-14-121-842-_-Product
Should be good.
