How to use a cable for usb-usb file transfer from XP to win 7 using Direct-Linq usb-usb cable
G
Guest
Guest
I have data on a Toshiba XP PC and want to transfer it to HP Pavilion Win 7 PC. I have an Alohabob Direct-Linq usb-usb cable. How do I set it up? Driver? Set up on PC's. Thank you.
G
Guest
Guest
From amis41, Thank you.
I have successfully connected the two computers using Windows Easy Transfer. The only problem is the speed is slower than a snail going across a yard stick - Estimated 3 Days. It started on my photo file but after six hours there is a long way to go. I trimmed out the files that were not photos, documents, videos, to make it faster but the program still quoted the 91 Gigs to be transferred, and I think it should be much less. Thank you very much but am still monitoring for responses and ideas. I am going to transfer a file or two at a time to allow the PC's time to rest. XP is very SLOW. Peace and goodness to all.
Similar threads
