News How to Use an Android Device to Write Raspberry Pi SD cards
juanca1944
Commendable
Jul 21, 2020
Strictly speaking with the cell phone is enough, since it has a slot for a micro SD. Before the "imager" I use it regularly.
Apr 12, 2023
If you use the internal micro sd card port for most smartphones, they will be formatted as either internal storage, or combined with internal storage. Better to use an external card reader with an otg cable, or otg hub with built in card readers.
May 2, 2024
Im trying to install a custom OS that is an official Raspi 64 bit OS on my OTG SD card using this app and getting a java su error. The compressed img file was downloaded from the official Raspi site to a folder on my S22+ phone. Any tips or advice? As a side the instructions work fine for one of the built in 32 bit OSes on the P4 list included in the app.
Thank you in advance.
Steve
USAFRet
Steve
Please start a NEW thread for your particular situation.
This one is ancient.
