[SOLVED] how to use case with only Reset switch no PWR Switch
Jun 23, 2020
11
Hi been trying to work out if theres a possible way to use my NEW PC case which ive managed to destroy the PWR switch off the board on the case.
All you need is a momentary switch. You could use the reset switch on the power connector and it would work fine although then you don't have a reset. You can wire a switch and attach somewhere too.
