how to use Commander PRO
zekenzy21
Commendable
Apr 3, 2016
21
Hi All,
I consider to buy corsair commander pro.  You know, every RGB fans come with 2 cable :
1 is  fan cable for fan get power and spinning.
Second  one, is RGB fan cable so the fan get power and light up, lighting effect.
I was looked online and see corsair commander pro, they can connect 6 fan.  If that is  6 fans connect for fans get power and spinning. How I can connect second RGB cable to commander pro ?
Any help, I'm appreciate.
Thank you.
The commander Pro works only for Corsair fans. If you buy the fans and want to control the LED portion you connect the LED Node that comes in the kit (2 fans and the node) to the COmmander Pro and then the fans connect to the Commander...
The commander Pro works only for Corsair fans. If you buy the fans and want to control the LED portion you connect the LED Node that comes in the kit (2 fans and the node) to the COmmander Pro and then the fans connect to the Commander Pro for power then the LED Node for LE as in the image above.
http://forum.corsair.com/forums/showthread.php?p=939680
Thats a great post on how you can connect multiple things to it. For example I could get a Commander Pro and connect both my H100i and AX860i to it then the Commander Pro to a USB hub instead of having to use 2 USB hubs then to my LED Node for my HD120s and use it to control the fans LEDs,
Latest posts
