[SOLVED] How to use Eathernet+WiFi on the same PC!
Kisuke42
15
Hello all,
I have unlimited but unreliable WiFi connection. I also have good Ethernet connection but with a download limit.
I play online and want to use my Ethernet for games only and WiFi for everything else.
How do I do this on Win7?
Thank You.
Using a Powershell script.
if( (Get-NetAdapter -Name "WiFi").Status -eq "Disabled"){
Disable-NetAdapter -Name "Ethernet"
Enable-NetAdapter -Name "Wifi"
"Wifi enabled, Ethernet disabled"
}else{
Disable-NetAdapter -Name "Wifi"
Enable-NetAdapter -Name "Ethernet"
"Ethernet enabled, Wifi disabled"
I use to do the same thing when I lived in the boonies and had a metered connection.
}else{
