How to use integrated monitor speakers along with the monitor 3.5mm audio out?
Yashtrave
Commendable
Aug 1, 2016
39
So I recently bought a monitor : Asus PB278Q
I have headphones connected to the monitor(located behind the monitor so not easily accessible) and would like to know if there is a way that I could use my monitors speakers without having to unplug my headphones every time since I literally have to move my monitor all the way around to plug in the headphones. My PC is mounted on the wall so it isn't convenient(or looks good) to plug in my headphones up top. I hope the diagram helps make sense of the situation.
https://postimg.org/image/efbdt24sz/
hmm, that's an interesting way of doing it. Only will work if you have Stereo Mix though.
Windows does not support using 2 audio devices to output the same sound at any given time (unless you have a receiver with 4 outputs connected as stereo {a and b speakers}) what windows does support is Stream Routing where in essence you can choose what application uses what audio source.
http://superuser.com/questions/329147/how-to-use-two-audio-devices-simultaneously-with-windows-7
You do know that most audio drivers allow both headphone and rear to output the same stream right?
Basroil is right. I know that I can have dual output if I was using my Motherboard audio jack along with the monitors speakers, but my question is mainly dealing with the Monitor audio jack AND the monitors speakers themselves. I think I may just have to buy a small 3" 3.5mm extender.
I've only really seen gigabyte drivers that support this and regardless he's trying to use it through his monitor. Windows does not support this feature native and I've yet to come across software that does.
1) Pretty much all realtek drivers do actually, as far back as the pentium 4 era....
2) He just wants to be able to switch between headphone and speaker, not use them at the same time (at least that's what his post says). For that all you need to do is use two different outputs and switch them (click on volume and select a different output in win 10)
