Hello,
I'm trying to turn on the RGB for my front fans. I plugged in the 4 pin connector to the LED_2 header, but nothing happens when I turn on the PC. I have attached some pics to show what I mean. The manual says I need to set the LED_2 header accordingly. I think I'm supposed to use 5V. If I do need to use the jumper, what cables do I use?
View: https://imgur.com/a/SPKM6NT
Components:
Mobo: Aorus B450 Pro Wifi
Case: Deepcool Matrexx 70 RGB
Thanks for your help!
Components:
