Hello ,
Here's the Existing setup:
1. I have a internet cable that comes in to the home from one corner.
2. The line is connected to modem which creates the WIFI network.
3. I have a samsung c series LCD TV(2009-2010 model) which has LAN port.
4. My wifi modem is too far from TV, and i can't use the cable to connect to TV.
This is what I am thinking of doing:
I want to buy a wifi repeater and place it near TV . Then, I want to connect my TV to the repeater with RJ45 cable. The repeater can strengthen my existing wifi signal (Which I use from laptop and phone), and can also provide connection to my TV through wire.
So my question is ,
which kind of repeater should i use ?
Is there anything required to configure for the wifi repeater?
(as explained above other than giving power supply to wifi repeater and connecting it to TV with LAN , there is nothing i can do actually.. am i correct?)
Also there are many wifi signals nearby ,so repeater will try to strengthen all the signals?
Also what ip details should i give in my TV?
Thanks,
Ravi
So my question is ,
Thanks,
Ravi
