How to use laptop hard drive as a external usb drive
G
Guest
Guest
Hi,
I just refurbished my laptop with new hard drive and I would like to use my old laptop hard drive as a external usb hard drive. Is it possible? Any one can help me.....
Ankit
Hi,
Ankit
I'm using this enclosure for mine: http://www.newegg.com/Product/Product.aspx?Item=N82E16817503003&Tpk=tip-230u3-bk It's USB powered and it works on all systems except for old ones that provide very low USB power. It's easy to carry around, but if you don't have that requirement, then a powered case might be better as it requires a single USB connection.
