How to use wifi while using ethernet
n1Mogs
Hi all. there is probably an easy answer to this question. i have searched all over and either found other answers or half the answer.
Basically i am using Ethernet since the other day for internet, i do have WiFi as well
but today i came to use my Msi monitor on my phone and couldn't connect to the pc as its no longer WiFi. so my question is how i can i still use WiFi while connected to Ethernet ? for devices or other things ?
Cheers Mogs
Hi thank you for your reply.
it still is WiFi but for some reason some things wont connect to my pc that are trying to use WiFi since i have Ethernet on.
what im using or was using is command centre for MSI Mobo and there is an app on android that i was using to monitor it.
but since i connected via Ethernet its no longer able to connect.?
WiFi and the Ethernet would be going to the same network, is the issue with the app connection to the PC? Try uninstalling it and setting it up again.
Latest posts
