also worth noting.... its fairly easy to find wall-warts (the wall plugs with transformers built into them for say... phones) which are capable of the output v/a that you're looking for and wiring them up. i've used this a few times to power fans on the cheap but on its own its just going to be straight on/off with no adjustment.
similarly you can likely get a wall-wart to power a fan controller if you get one for the appropriate v/a required. the benefit of a power supply is that it cools itself but its also large and not so easy to hide.
they do make some smaller thermal controllers for fans if you felt like a little DIY work.
if you want simple plug and play... then as alex suggested using straight pc parts would work though...
