How to wire a 4 wire fan to battery
Try red and yellow together on positive terminal and black on negative, thats a 17v starting volatge, otherwise im at a loss.
Looked yellow when I googled it.
Ahh, have...
What ???? this makes absolutly no sense, are you talking about a computer 4 pin fan, what sort of battery ? they way you sounded this makes it sound like you should be asking this question in a car forum, pictures say a 1000 words.
If you're doing what I think you're doing, you need to google whatever fan you have, and find out what the wiring scheme is for it. That should tell you what the + and - cables are, and then you can connect them to the corresponding battery terminals.
1. Battery
2. Fan, with 4 wires
Strip a small section of insulation off all 4 wires.
Try all possible combinations of the 4 wires to the + and - terminals of the battery.
When it spins, you've found the correct ones.
If it spins the wrong way, switch them around.
If it never spins, either the fan is broken or the battery is too weak.
Yellow is your 12v live, red is the 5v live, black is ground and Blue/Green is signal.
Put yellow on positive terminal and black on negative, the fan will run at 12v
Put Yellow on positive terminal and red on negative, fan will run quieter at 7v
Put Red on positive terminal and black on negative, fan will run at 5v.
Unfortunately I have tried all of those and it has failed to work
The fan does work and so do the batteries
Ahh, have you tried just red and black ?
