[SOLVED] How to Wire EVGA CLC Water Cooler to ASUS Prime x370 Pro Motherboard
Feb 14, 2019
This is my first PC build, and all fans are turning. I'm just unsure where all the wires are to go on the motherboard. As an example, the cooler has one set of 2 cables labeled "to fans" and one labeled "to motherboard". I connected the motherboard one to the CPU header but have no idea where to connect the others to. Also, the case is a Mastercooler Masterbox MB500. It has a set of leads from each of the 3 case fans that come together but I don't know what to do with them either. Please help! I really need a scematic that shows where all the wires are supposed to be plugged in for my specific hardware. Instructions that came with all components were very vague and unhelpful. Thanks
I've struggled with this as well with my EVGA CLC280. You have a different motherboard, but thanks to the internet I was able to snatch a very high res picture of your motherboard.
Near the 3.5MM sound cable plugs, you see a chip called LANGuard. Next to that you see two connectors there. The one closest to the LANGuard chip is the AIO_PUMP header. Connect the lead that says "To Motherboard" there. Don't use the one next to it, that one's CHA_FAN1, which as you may have guessed, is purposed for a chassis fan.
The two fans that are on the radiator are supposed to connect to the two fan headers to the right of the top-middle hole of your motherboard. One is white, one is black.
