Hi Folks!
I posted a second question today, but am replacing my AIO and my fans in my case. It is an MSI prebuilt computer that is about 2 years old now. I have ordered an MSI AIO and then four additional 120mm fans. I am replacing all fans at this point, so it will have three in the front of the case as intake, one in the rear as exhaust, and the AIO will be venting out the top as exhaust.
The prior setup had the AIO and an RGB controller. The RGB controller looks to just be a board. I'd like all fans to run properly and be synced with their RGB colors through the MSI software.
I have ordered the items below. What is the best way to hook up the fans / wire them? I used to build PC's about 20 years ago, but am so far removed that I am completely lost here on what to do. Do I need more components to control the fans, or a central RGB controller? Should I use splitters and wire the fans to the AIO? Just pretty confused, appreciate anyones help.
AIO:
https://us-store.msi.com/PC-Components/CPU-Coolers/Liquid-Cooler/MPG-CORELIQUID-D240
Fans:
https://us-store.msi.com/PC-Components/CPU-Coolers/Case-Fan/MPG-F120-ARGB-2B
PC Setup:
https://www.newegg.com/msi-aegis-rs-10tf-214us/p/N82E16883152953R
Intel Core™ i7-10700K 8 Cores 3.8-5.1 GHz 16M Cache
NVIDIA® GeForce RTX™ 3080 Ti 12GB GDDR6X
32GB DDR4 3000Mhz (16GB x 2)
2TB M.2 NVMe SSD
2TB 3.5" 7200 RPM HDD
Intel® Wi-Fi 6 AX200 2x2 802.11ax (2.4Gbps)
MSI’s LED Button - Customize your desktop with 60 lighting effects.
Latest Wi-Fi 6 (802.11ax) for redefined wireless gaming experience
Easy to upgrade with standard MSI components and case
MSI Z490 Motherboard - A durable high-performance motherboard made for gaming.
120mm Dragon CPU Liquid Cooler for optimizing heat dissipation
AIO:
Fans:
PC Setup:
2TB M.2 NVMe SSD
