How to wire RCA cable?
Correction, it only has 2 pre amps, the 3 pre amp out is sold as an upgrade, just use a Y RCA adaptor ( http://produto.mercadolivre.com.br/MLB-589855512-npc158-adaptador-t-rca-1-fmea-2-macho-linha-golden-_JM) to pass the front channel to the rear. If you listen to music in 5.1 or use dvd movies buy the upgrade kit, if not, use the Y connection to give you another pre amp out to amp, then Switch setting checklist:
- CH 1 / 2 X-OVER: FULL
- CH 3 / 4 X-OVER: FULL and MODE:“5” since 3 sets are connected. In the bottom of the amp user manual it's stated to use a Y connector as i said. You will get Separated Sub controll within the head unit. You can also use only one pre amp for all the sistem but no Sub/Speaker separation control on head unit
Hi,
The head unit has 3 line outputs...
3 Sets of 2V preamp outputs (front, rear and subwoofer)
2rca in one cable for front, 2rca in one cable for rear and 2 rca for sub. You need 3 2xrca cables to connect it to line input. The outputs to speaker and sub is self explanatory... ch5 is sub and the ch1-4 is thes speakers.
tHV4rR
