Question How to wire this usb camera to a usb cable?
mgw1122
67
So I have this lenovo camera with different colored then the standard usb cable does. I figured out the power cable. I'm guessing black is ground. But the camera has a white and yellow cable while the usb has a white and green. When I try all combinations usb device isn't recognized. There are some fixes for that but I need to wire it properly first. Any Ideas?
Not finding what I would consider an acceptable camera pinout with respect to the Sony camera.
On the Sony camera PCB (Printed Circuit Board) take a careful look to discover any markings that may identify the source manufacturer.
What makes the USB connections difficult is that some manufacturer's do not follow standard color codes and use their own proprietary connections.
The following link may help get a sense of it all.
View: https://www.youtube.com/watch?v=g8XbDJLKKys
