How Well do These Components go Together?
Zalphox
Commendable
Dec 23, 2016
Hey, i'm looking to build a fairly good pc, one for gaming a ultra 1080p as well as edit/render films. Both from time to time and of equal importance. I also want this PC to be easily upgradable and flexible to work with, and possibly even future proof. If you could tell me if it's good or not, or have any suggestions for improvements, possibly with cheaper or more powerful alternative components, that would great!
Build:
Case: Phanteks Enthoo Primo Ultimate Chassis White
CPU: Intel Core i7 6700K
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Asus Z170-AR
RAM: Corsair Vengeance LPX CMK16GX4M2B3200C16W 16GB (2x8GB) DDR4
GPU: MSI GeForce GTX 1080 ARMOR 8G OC
Power Supply: Corsair RM750i 80Plus Gold 750W
Every Thing Is Perfect :)
But First Of All For Fhd Resolution Playing Ultra U Dont Have To Waste Ur Money And Affording A 1080 Gpu :/ 1080 Is For 4k / 1070 For 4k And Qhd / 1060 For Qhd And Fhd :) Although i Dont Know Anything About Editing Films Or E.t.c If It Needs 1080 So Buy it But For 1080p Gaming 1060 6gb Is Sufficient
So I Suggest U Save Ur Money And Afford A Gtx 1060 6gb Version
K Series Cpu For Oc With Z Series Mobo : Its Compatible And Ok
Ur Psu Is 750 Watt : Its Ok :)
Also Sugest U Afford A Solid State Disk Too (SSD) :) It Increase The Speed Of Jobs In Comparing With Hybrid Or Hdd Storages :)
Its A Good One If U Can Afford It :)
https://pcpartpicker.com/product/RGPzK8/kingston-ssdnow-kc400-256gb-25-solid-state-drive-skc400s37256g
Or
https://pcpartpicker.com/product/ZPbp99/transcend-internal-hard-drive-ts256gmts400
Regards :)
