How well will my build run dolphin emulation
nightfox360
5
Recently i upgraded my PC to a AMD A6-3670K Unlocked Llano 2.7GHz from a Core2Duo E7500 2.93GHz so i wanted to know how well it would run games on dolphin emulator, im mostly looking to run Monster Hunter tri. any help would do.
Should probably run pretty decent on that, most emulation is CPU based, so the built in GPU of that chip would be enough for the graphics side and Dolphin only uses a max of 3 cores, so the quad core is fine and the game you want to play runs nearly perfect on it with little issues.
I tried dolphin long ago on Q6600 and it worked well already.
I guess your rig will perform better :)
Some thoughts:
I installed it but threw it away only after several hours although I worked smoothly.
The graphic quality of a Wii is really §&%$&%§!!
I can not imagine why people bought it...I even tried to play a game using a real Wii...
it sucked big time..
any ideas on what settings should be used
Well, because your processor won't run Dolphin very well (see: https://dolphin-emu.org/docs/faq/) probably enabling safe speedhacks, use DirectX9 (assuming you are running Windows) and playing around with the graphics and emulation settings until you find a spot you like.
