How will a GTX 295 run on my system?
adras_22
System Specs:
Intel i5 750 (@2.66ghz)
Motherboard: Gigabyte P55-UD3
RAM: 2x2GB 1600mhz DDR3 (x86 so only 3.5gb useable D: )
In the process of upgrading my generic 850w power supply to a 1100w silent pro.
Just wondering if I can get what I pay for with this card?
You should have no bottlenecking issues, maybe a light overclock would help, but you should be fine. As for the power supply, all you need is a good quality 750w, and I mean GOOD QUALITY. Even an average 1100w is not recommended. Get one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341011
Also why the GTX 295? The 5870 is basically just as fast, has DX11, and is a single card system so won't be an issue in the future (SLI/cfx tends to be problematic). Oh its also a lot cheaper... Hell for a bit more you could get a 5970, which destroys a GTX 295.
