How will this build work?
CompJohn
14
This is all compatible and will not bottleneck each other. I would change the motherboard to the Asus M5A99FX Pro R2.0 or the Gigabyte GA-990FXA-UD3 for better light overclocking. If you are going over light overclocking, I would go for the Asus Sabertooth 990FX R2.0 motherboard or the ASRock 990FX Extreme 9.
+1 for getting a better motherboard.
Good budget board for overclocking = Gigabyte GA-970A-UD3P
It has 8+2 phase power, LLC and decent cooling on the chipset and VRMs. Got my FX 6350 to 4.950GHz on this board with a Corsair H110 for cooling.
Good Midrange board for overclocking = Gigabyte GA-990FXA-UD3, or UD5
My personal favorite board for overclocking = ASUS Sabertooth 990FX
You will need good cooling to OC an FX 8 core CPU. So look at something like a Noctua NHD14 or Phanteks TC14PE.
