How would a power connector to my cd drive short out?
Wow! Looks more like a big spark to me.
A heat up/ burn would have more carbon upwards versus off to the right as shown in the photograph.
Per jsmithepa's reference it was like a small incandescent light bulb: however, the connector "blew" with a significant flash/spark.....
I would suspect that a short developed in the connector and during a period of heavy use the current flow heated things up and all melted.
Cannot really tell much about the quality of the connector per se but even a "good brand" could have a defect.
Any problems with drive that you can remember?
Google the cable manufacturer and see if there are any reports/complaints of similar problems.
Possibly could have been a problem in CD drive's port but personally I would think the cable more likely.
How does the CD drive port look?
Playing some XXXXX stuff? 😀
KIDDING!
Unusual but not impossible. Poorly made cable and/or dirt got into the connector and just enough of it for it to form a "resistor" like a small incandescent light bulb. At least your drive survived. I would attempt to clean the drive connector with a tinny hobbyist wire brush before you put it back together, then monitor it for a couple of days, it should feel room temperature.
