Question How would I know if I need ATX or microATX case?
colat
78
I want to upgrade/change my case. How would I know if I need ATX or microATX case? The motherboard looks smaller in the current case.
If you know the model of your motherboard you can tell us/search about it
To know what your motherboard is
Download and install CPUZ and it will tell you what it is
You have a bunch of posts asking about new motherboard, cpu, drive, etc... Take a minute to think and put your questions in one post in the systems area about what components you are looking to buy and stick with one thread. Seems like you are trying to build a new computer, it won't help if you post a new question each day. Figure out what you are trying to do, and ask the right questions. You are asking about a case here, a new drive here https://forums.tomshardware.com/thr...ill-you-suggest-to-buy.3486580/#post-21074210 Motherboard here https://forums.tomshardware.com/thr...-generation-intel-processor-with-m-2.3486315/ another question about a drive here https://forums.tomshardware.com/thr...sata-3-ssd-motherboard-supports-both.3486287/ CPU here https://forums.tomshardware.com/threads/which-intel-processor-is-the-best-now-to-buy.3486247/
