G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Hi,
I have a HP1220c that is about 3 years old. Recently it is refusing to
work - most of the time.
Sometimes it can be persuaded to print and will then print fine for a while.
Once it has not done anything for a few hours it will be back to playing up
again!
When you turn it on it will sit there constantly
nudging the ink station wiper mechanism towards the back of the printer.
Having reached its limit it is still nudging the motor every 4 seconds or
so. At the same time the power light blinks off for a moment.
It was that behaviour that made me get a new motor for the ink station -
thinking it was not working right. (The mechanism moves easy enough)
After up to an hour of this it will either error out or move on to running
the paper feed roller and moving the print head back and forth.
In between doing this every 10 to 20 secs it will buzz from the ink station
motor.
After an hour or so of this it might decide to put the ink light on....after
which it might agree to print something. At least that's what usually
happens.
Once it works - everything works... ink station cleaning...paper pick up etc
no problems - it just does not last long.
Sorry for such a long ramble! If anyone recognises what wrong with it I'd
love to know about it. Even if it's terminal and it need to go in the waste
bin.
thanks
Robert.
Hi,
again!
motor.
happens.
bin.
thanks
Robert.
