Update !!!
I took a chance and made the purchase. Very bad decision!
If you are in the market for a monitor for playing games, I would definitely
not recommend this monitor.
1)
Very washed out colors and everything seemed
way too bright. I tried adjusting all the settings but could never could get it to look good. There is a gaming setting which made it even worse.
2)
Very bad viewing angle. Even if it's just a few degrees off to either the right or left.
Conclusion: This may be good for an office or everyday computing but do not make the purchase if you are a gamer.
I have since returned it.
If you are looking for a nice monitor at a decent price, try the
LG W2753V 27" Monitor. It has a better Contrast Ratio and a faster response time. Check it out at Newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005127
Note: For the LG W2753V Monitor, read the manual before turning the monitor on for the first time. You will find 2 things in particular while reading it that I found important.
1) Allow the display to stabilize for at least 30 minutes before making image adjustments.
2) If you are having problems with the buttons, press the "Smart" button on the monitor and set the "Live Sensor" to the "Off" position. When in the "On" position, this function turns on the button LED for pushing comfortable. It detects the presence of the users hand before touch it. This drove me nuts and was very difficult to maneuver so I turned it off.
I hope this helps.
