G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Hi,
I've got a couple of HP 4 + printers which are setup as
TCP/IP with JetDirect internal cards. They are shared from my main server
though they are not directly connected to the server (Win 2003). When I
print from the server everything is fine but when I print from any other
computer on the network I get an extra form feed
between each printed sheet. In other words a blank piece of paper will be
between each sheet with printing on it.
I can setup the printers as direct TCP/IP printers in the clients or use the
server's share and the result is the same.
Anyine have any ideas? They used to work fine.
Bill
Hi,
Bill
