Question HP 8200 Elite upgrade gpu to rx 580 and power supply, need your help
Feb 28, 2019
Hey guys i have a HP 8200 Elite, i have a gigabyte rx 580 8gb and it requires a 500w PSU and im thinking to buy a Xtreme gaming energy 525W 80 plus, i just wanna know what do you guys think and if there will a problem or not and thank you
525W would be enough. However, HP uses a propriety power supply design. If you search the net for "HP 8200 Elite power supply" you will find a video on how to modify a standard ATX PSU to work. You might want to consider letting a competent local PC repair shop handle the modifications. Or search for a pre-made adapter.
HP_Z240_ProDesk_600_Compaq_Elite_8300_CMT_PSU_Main_Power_24-Pin_to_6-Pin_Adapter_Cable_%28Standard%29__73021_zoom.jpg
Have you install the RX 580 8gb card? The PSU fits on the HP 8200? Did you have problems with the adapter cable? Do you have the CMT version of HP or SFF?
