G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I`ve had this printer for 8 years. Light printing usually with an occasional
large file.
The print test shows the color fine; no banding or different intensity.
The black cartridge has been replaced twice.
After a week or so on the first one, ink smeared on the paper and there was
quite a bit of ink all over the head of the cart.
Another cart, in for 2 weeks, was similar but so far hasn`t smeared the paper.
The half inch high HP DESKJET 850c TEST LINE has a 1/8inch white band thru the
center and none of the black ink is as dark as it should be.
Other black test printing at the bottom is almost unreadable.
Color patter blocks are fine.
I`ve cleaned the cartridge contacts on the print head and the cart.
Advice?
Many Thanks
Regards Buddy B
large file.
Advice?
Many Thanks
Regards Buddy B
