Is there a difference between a HP CC09 and CA09 battery? The voltage, length, and docking all look the same. The only difference I can see is where the charge pins are, the CA has square edges and the CC has one square edge and one round edge and it appears the Laptop housing will take either square or round. However, I may have just seen a bad pic of the CC. (The pic of the CC had the one rounded edge at the pins). Part number 628666-001 and 718677-421. Thank you for your responce.
