HP Compaq 6000 Pro SFF Case Swap
ronanb
5
So my first “gaming rig” isn’t much to game on. It is a HP Compaq 6000 Pro SFF, which I upgrade with a Core 2 Quad processor, a GT 1030, 6GB of RAM, and Windows 10. It was more or less an experimental/learning pc building and upgrading experience. Now that I have built my own, I decided that I would give the HP to my little brother for his birthday, as he can play some of his favorites. The only problem is that when I first got it, I figured what better way to help the exterior look then to spray paint it, as it was refurbished, and had some noticeable cosmetic issues. Time has taken its toll on the paint job, as it is wearing away on some bits and looks like crap. I figured I would buy a case and power supply and move the parts to a new case. However, I’m not quite sure what case would fit my particular motherboard. I’m not looking to spend a lot of money on it. Help Is much appreciated!
Update: I have a dell Vostro 200 motherboard that can run my CPU, not to mention a 300W power supply with it, so would this motherboard allow me to swap cases?
How bad is the aging on the case? I don't suppose you could sand the case down with 600 Grit paper and repaint it and then after 3 coats apply glossy/matte clear lacquer to protect the paint from the elements...? You see, I''m advising against a case swap since the board and the connectors inside it are proprietary as well as the PSU, which will mean that your assumed 50USD investment can quickly turn into a 100USD+ nightmare. I would say to leave it as is and deal with the cosmetic issue with some spray paint from your local automotive/DIY store(after asking your brother what his favorite color is) and seal the paint with clear coat.
MERGED QUESTION
Question from ronanb : "Possible Case Swap?"
Long story short, my first “gaming” PC was a refurbished HP Compaq 6000 Pro SFF that I upgraded with a Core 2 Quad processor, GT 1030, 6GB of RAM, and Windows 10. Not much to game on, which is why I built a new PC. I decided that I will give my old PC to my little brother for his upcoming birthday, as he can play some of his favorite games. I previously painted the case to cover up cosmetic damage, as again, it was refurbished. However, time has taken its toll on the paint job. So I decided that I would buy a case and transfer the parts. However, due to the unique shape of the motherboard and power supply, I decided that I could put the CPU in the motherboard I scrapped from my Dell Vostro 200, and use the 300W PSU I had from it. I’ve looked into some cases, and was wondering if any in particular would fit the Dell motherboard? Preferably something cheap. I appreciate the help!
Stop recreating the same thread. It's best to keep thoughts on one thread. On another note, you might want to look at the motherboard's front panel connector block+the PSU's connections to the board + the PSU in the chassis = they will cost you more than a minor expenditure.
