Hp DV5 1235dx do not power up
championx
Hi! i have a problem with my laptop. I cant make it power up. Removed battery and connected to the ace adapter and nothing. Not even the leds. Just the power adaptor jack led.
I did all the steps that hp suggest, but nothing.
I think I need to change some component on the motherboard, do anyone knows wich one?
If your getting a a light on the power port then try an atx reset.
This is done by removing the battery and power cable from the laptop , holding down the power button for 15 seconds( you will see nothing happen) then release. . Plug your charger in and see if it helped..
If still no power try another power supply.
Then if atill.not working the main board is the fault
Good luck
Good luck
