OK. The dvd drive on the above mentioned machines motherboard has the following Micro SATA cable. The lead connects to the MB by a standard SATA HDD cable and a weird 5 pin connection. Only 4 of those power connections are populated on the white connector but it is 2 red and 2 black.
As I have no use for the DVD I am trying to get that connector converted to a standard molex 4 pin connector to provide power.
Any one know how to convert the 2 red and 2 black molex off the five pins on the board.
This is one of the only pics i could find and you can see the 5 pin next to the sata.
[/img]
Hope you can help.
thanks
Hope you can help.
thanks
