HP Elite 8300 SFF + 1050 Ti OC Will it Fit
cubernix
Hey there!
I am planning to buy a Prebuilt HP Elite 8300 SFF and A 1050 TI OC not the Low Profile
Will It Fit and Will It Work? Thanks
actually, u had to check this one on your own, as u're the one who had the PC
Just measure the case size
also remember that non-Low profile GPU usually are 2-slot width (it's their thickness)
my 2 cents:
i don't think it would fit, low profile cards are made for a reason
for the will it work:
seeing that ur CPU should be around 2nd / 3rd gen, the latest BIOS should support a new gen GPU, so that should be fine
as long ur PC had the PCIe 16x slot and enough juice on the PSU, it'll work (recommended at least 300w for a GTX 1050 Ti)
my 2 cents:
Seems some one has posted a video with a 1050 ti with that pre-built PC. So this should work.
https://www.youtube.com/watch?v=s_j38Kt0uJA
The main concern of your PC case is the width. Seems the Zotac card (links below) has a width of 11 cm while your case is 17 cm long, so shouldn't be a problem.
https://www.zotac.com/us/product/graphics_card/zotac-geforce-gtx-1050-ti-oc-edition#spec
https://support.hp.com/us-en/product/hp-compaq-elite-8300-small-form-factor-pc/5232852/document/c03345460
Do check out some small form factors card available, like this one, 1050 Ti OC:
https://www.msi.com/Graphics-card/GeForce-GTX-1050-Ti-4G-OC.html
