Question HP Envy x360 15-ds1063cl not power on
Oct 21, 2024
4
Hello.
A few months ago my laptop started refuse power on or wake up commands. Not every time, maybe 1-2 times a week. After a few minutes of pressing different buttons he woke up as usual. Currently is compeletely off.
On power button press led indicator lighting up for 5-6 seconds, then turning off for 5-6 sec and go into a loop ON/OFF for 5-6 sec . Same for both fans. Looks like the laptop is trying to power and going OFF. SDD becomes warm, the screen is black. The laptop is not starting without a SDD stick. It doesn't matter the SDD is connected or not, same symptoms. Sometmes there is no loop, the indicator is on and fans are not spinning.
I tried EVERYTHING what HP bots offer as quick fixes. Connect external monitor, BIOS reset, 60sec+60sec pressing, remove battery for a few minutes (even overnight) Nothing help anymore.
If it is hardware related symptoms, can you point me to a good troubleshooting guide? Youtube videos are useless. I have basic knowledge of vintage electronics, can read schemes and repair some simple stereo receivers, but know nothing about modern electronics. HP website doesn't have service manuals with schemes, what they call "service manual" is useless files with dissasembling instructions.
Thanks.
View: https://youtu.be/hsR3JlZVwew?t=415
Remove the stick(s) of ram(after disconnecting the battery), use an eraser to wipe the gold contacts on the ram stick(s), wipe clean off of any eraser lint, then reseat. Try and power up without the battery attached to the laptop, using only the power brick/adapter.
Chances are your laptop's motherboard is fried or has a short of some sort. If you're yet within warranty period, you shouldn't tamper with the motherboard.
BIOS reset
Did you try BIOS recovery mode? If not, then look through these;
View: https://www.youtube.com/watch?v=zdb2e6hFl38
View: https://www.youtube.com/watch?v=qpiGUojtr3E
View: https://www.youtube.com/watch?v=KT4GQsgPXyA
Hope this helps.
