Question HP Envy x360 LDplayer multi instance crashing problem
Hi ,
Currently trying to play 4-6 instances of a game using LDPlayer , but for some reason instances crash and freeze after playing more than 3.
I upgraded RAM a few days ago from 8gb to 16gb which helped memory go from 85% usage to 50% while playing 3 instances. However , instances kept crashing when playing 4-6 instances, , even with CPU at 50% and RAM around 55-65%.
Have tried to format disk and fresh install, update drivers using Advance System Care 12.3 ( not sure if it's the best program ) , set priority to above average on LDplayer instances , changed battery settings to maximum performance, increase core usage on LDPlayer to 2 ( didn't work ), check if VT virtualization is turned on, update Windows, and have tried other android emulators in the past ( LD player worked the best ) .
Are there any other things to do to optimize performance and help PC to run more instances? And shouldn't the laptop be able to run 6 instances since 5-6 instances only use 55-65% RAM and 50% CPU , or is it an emulator / set up compatability problem ? Thanks in advance
