Hp h8-1234 motherboard front panel pin layout
G
Guest
Guest
I need help ASAP, i had to get a new case for my HP h8-1234, and i don't know what front panel connections go where! Please Help!
If not standard, then trial and error will work. Finding the power switch and the reset switch is easy. Then you need to figure out which pins are for the power and disk LEDs. There are no risks, but LEDs have to be connected properly to work; you have to reverse the connector for each pair if the LED isn't lit.
There's a good chance that the layout is this one: http://www.google.ca/imgres?imgurl=http://www.intel.com/support/motherboards/desktop/sb/img/fp_header.jpg&imgrefurl=http://www.intel.com/support/motherboards/desktop/sb/cs-009016.htm&h=246&w=351&sz=25&tbnid=UuAquVX0QstuZM:&tbnh=90&tbnw=128&zoom=1&usg=__L_OjqpiIatqr6gMqSSjLXHXWf70=&docid=l1wqDIa-Dts0NM&sa=X&ei=EqQJUZ2II7P44QTZu4GYBw&ved=0CDIQ9QEwAA&dur=2405 where pin 10 is not connected.
G
Guest
Guest
Thank you! And the image u put in was my pin layout. Hp would not tell me anything, so i went searching myself and found the exact same thing. :D Thanks again!
