HP LaserJet 1100 feeding problems
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
My LaserJet 1100 suddenly started grabbing several (like about 5)
sheets of paper at a time when printing.
Why is this happening?
Can this be fixed?
TIA,
NJ
G
Guest
Guest
Other than that are you satisfied with the 1100 (current model 1200);
especially print text quality. I have a 990 and have read that the 1100
with the separate ink tanks and expensive replaceable print heads went
down in print quality for business documents.
For business use, my HP 990Cse has a fabulous draft that rivals normal
quality from other printers but is faster. The standard print quality,
while slower is even better. The high quality mode is seldom used
because it is very slow and only marginally better than standard.
>Can this be fixed?
>TIA,
>NJ
G
Guest
Guest
The original thread was about a feed problem on the HP LASERJET 1100. What
are you talking about ?
> >Can this be fixed?
> >TIA,
> >NJ
alsam
4
Yes and no.
Mine started doing it a few years ago.
Do a search on HP's customer support forums.
HP used to send out a free cleaner that would help solve (temp) this.
Since they have not made this printer for several years, it might not
be available.
It seems to be pretty common, whenever I see one, I always ask about
the problem and everyone has said yes.
I have cleaned mine several times. The problem kept returning.
I now use it as a back up printer at home with only a few sheets in it.
It drove me to upgrade!
Good luck.
G
Guest
Guest
Bummer, I was afraid of that. I guess it's time to check the Staple's
catalog and see what is available.
G
Guest
Guest
Thank you for the link. $20 is worth investing instead of buying a new
printer.
