Question HP LaserJet Pro M454dw Color Printer Stuck
Jack10525
82
Hello All,
I have a HP M454dw printer that is showing verifying on the display screen. The only solution I have found online is to unplug the printer for a minute or so. I tried this twice. The 2nd time I waited longer. Once I plug the printer back and turn it on it shows verifying again. This prevents the printer from being usable. Is it bricked?
Hello All,
This is for a different model printer but look at the post from MKazi -- https://h30434.www3.hp.com/t5/Print...s-quot-verifying-quot-constantly/td-p/6108521
I would try the process that is outlined. Seems like it can't hurt.
There is also this thread -- https://h30434.www3.hp.com/t5/Print...actory-reset-HP-LaserJet-M254-DW/td-p/7677880
A factory reset might help.
It IS possible you have a hardware problem.
