V vinoarenas78 Reputable Oct 24, 2017 11 0 4,510 Nov 5, 2019 #1 Is my HP Le1901W VGA only will work to my GTX 1050 ti 4gb using HDMI?
Solution Phillip Corcoran Nov 5, 2019 Yes it will work but you'll need to buy an "active" HDMI-to-VGA adapter/converter like this: https://www.amazon.co.uk/Cable-Matters-Adapter-Converter-Black/dp/B00879DM56
Phillip Corcoran Titan Moderator Sep 7, 2013 26,114 916 120,140 Nov 5, 2019 Solution #2 Yes it will work but you'll need to buy an "active" HDMI-to-VGA adapter/converter like this: https://www.amazon.co.uk/Cable-Matters-Adapter-Converter-Black/dp/B00879DM56 Upvote 0 Downvote Solution
