Yes, right up to the point that it fails. At that point you may wind up having to replace the printer. There's a reason the manufacturer set a limit on the life of that particular component. You would do well to follow the recommendation.....Can I just keep using the fuser?
The printer is telling me i need to replace the fuser. The fuser costs as much as the printer. Can I just keep using the fuser?
Thanks
